Heater Valve?
My independent Mech says I need a new heater valve to fix my "no heat" condition in my 98 XJR.... I trust this guy mostly...since he is a factory trained ex Land Rover tech now working on his own. My cars heat was working great...but my friend used some type of stop leak product on my car while I was sick in the hospital and he was driving my car. Shortly afterwards, my car quit making heat. My tech guy quoted 500.00 to fix it...
My question to you guys...is can I change this heater valve myself? where is it exactly? and does it require special tools or anything like that? Do I hafta take my dash apart to get to it?
also...I have a 97 xj6 im not really driving that much anymore...can I take the heater valve off of that car?
Thanks in advance
Bill
Thanks in advance
Bill
Thanks in advance
Bill
Thanks in advance
Bill
I had a no heat situation in my 99 XJ8 4.0 last week. I suspected the aux water heater pump was at fault, so I removed and dismantled it. I inspected the bushes and there was lots of beef there so I applied fresh grease and reassembled it. I bench tested it and it worked very well, and now the car is roasting!
Check the pump first, easier to get at and only 2 pipes to disconnect instead of 4.
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
