Help!!!!! Asap
Does the key turn all the way? Often times the key is used so seldom that the mechanism gets gunked up. Spray some cleaner, WD 40 or something I guess, and try to work the lock. It really should work.
There is a gas tank between the backseat and the trunk, that's not going to work unfortunately.
Vector,
No, not the valet key. I tried using the key fob + the key manually to no avail. Unfortunately it turned out that the rod came off the lock device. Cut a hole behind the rear licence plate. Have now wound a wire around the rod and mechanism to hold it in place. Put a thin piece of fibreglass over the hole (just in case the issue ever arises again I can break in easier than having to cut through a welded plate, especially if away from tools and electricity). Killed me to cut that hole, but in the end, it was the only way to solve the issue.
s type R JAG
07-05-2016 04:10 PM
