Help-Cd button on radio but no cd
IF you have the CD changer, it's in the trunk, left hand side. If you don't you may be able to add it - you can find them on eBay for around $100. Most XJ's have the wiring harness already there in the trunk. You can remove the trim cover from the left side of the trunk - the mount for the changer will be evident, and the wiring harness will be visible. You'll have to cut a hole in the liner if you add the changer.
You must use the Jag CD changer unless you plan on a major stereo overhaul.
Not unusual at all for any car manufacturer. Why would you have a unique head unit or face plate for every option.Imagine the expense of installing a CD changer if you had to replace the head unit as well.
My honda has a button for XM but no XM was/is installed. My Jaguar also has a phone button but no phone is installed.
