Help Deciphering Lower Control Arm Language
Hello Gentlemen:
Dealer says I need new lower control arm bushings.
I'm going to replace the entire arms, ball joint attached.
Here's what the parts company's website says:
Front LH Lower Rear Wishbone Arm
and...
Front RH Lower Rear Wishbone Arm
Is this what I need? I'm thrown off by the "Rear" designation.
Thank you very much!
SirJag
and...
SirJag
Each front lower arm is made of 2 halves , one is going to the front of the chassis the other to the rear of it. They are bolted together, making a V shape arm. You will need Front RH lower front +rear and Front LH lower front+rear. Each arm have it's bush(4 of them) only 2 have ball-joints.
RaceDiagnostics
09-13-2015 02:22 AM
