Help determining trim level
I do agree on the base model, charcoal grill inserts, no wood on the steering wheel, rims, etc., the white piping on the seats was maybe optional, maybe standard by 2003.
Seems they mis-routed the cooling hoses (thermostat and radiator -> expansion tank), pay some attention there as engine cooling is an important issue on these cars.
Looks you are in for quite a bit of work, welcome to the club!
ericjansen (06-22-2018)
I see what you mean: it looks like the hose going to the overflow needs to be disconnected and reconnected to the nipple going to the radiator and then extended to the radiator; the hose going to the radiator is actually the hose bent to go to the overflow bottle. As it sits now, the hose to the radiator is likely to burn through . . (that it?)
Jhartz (06-23-2018)
mrbingha
12-26-2012 10:27 AM
