Help diagnose engine/supercharger noise ticking and grinding
It has finally warmed up here a bit in chicago and I was driving with my window down for the first time in a while.
This noise must have developed over the past few months because it was not apparent before winter. The car has 80k, a history of regular maintenance, and generally well maintained.
There are two separate sounds I am hearing. There is a kinda lower grinding sound, accompanied by a higher tick.
Please take a look at my video and let me know what you think.
Received 2,675 Likes
vincent661983 (02-22-2023)
+1 pull the SC belt!!
Before you even bother starting the car after pulling the belt, spin the blower pulley by hand, back and forth, and see how it feels. If it feels a bit "springy" with a free lash of maybe 10 degrees or so, it's not an obvious coupler failure. If you get about 1/4 turn before you feel a hard clunk and the SC engages, then your coupler is toast.
If you end up pulling the SC and rebuilding the snout yourself, make sure you replace the valley hoses while you're in there. Even if they look good, just replace them to be safe.
I was able to pull the belt off today. With spinning the pulley by hand, there was no obvious play up or down or in and out. When spinning the pulley, I could SLIGHTLY hear two parts rubbing together, but the action was more or less smooth. There was no obvious clunking when turning the pulley. With the car started, it sounded identical to having the belt attached. Whats the next place to look for source of noise, primary chain tensioners?
It could also be the supercharger coupler...you will have to remove the front snout to confirm or reject my theory
stock:
https://www.ebay.ca/itm/115435017153...hoCd-wQAvD_BwE
vs aftermarket:
https://www.ebay.ca/itm/171730479320...Bk9SR4yGyaXOYQ
one has springs that introduce play so to absorb the variations that occur during belt speed changes, and the other (aftermarket) has no free play
some relevant stuff with GM superchargers:
https://www.cadillacforums.com/threa....254244/page-7
https://static.nhtsa.gov/odi/tsbs/20...37217-9999.pdf
stock:
vs aftermarket:
2003JagStr
12-23-2022 01:44 AM
