help me out please...98 xjr
Got a small problem with my 98 xjr... 117,000 miles had it for 20,000 miles and one year...no mechanical problems at all till now...
my car is very slow to warm up according to the temp gauge. Now that it has gotten cooler, it is very noticeable. The temp guage only makes it to the middle of the dial if I let the car sit and idle for about 15 mins...once i start driving, the cold ambient air takes the guage down toward the blue....if I run the heat, it goes down even further and faster...
Do I have a stuck thermostat? or what? A couple nights ago, the temp guage dropped all the way into the blue cuasing my restricted performance light to come on for the first time since Ive had this car... Parking it and cycling the key caused it to return to normal
Im thinking of replacing the thermostat....what do you guys suggest...? can I trust a local independent to change my Tstat?
Thanks in advance
Thanks in advance
WRONG! Very simple - 15 minute job on XJR! Been there, done that!
"A bit tougher on an XJR... I think the blower has to come off to do the job. Correct if I'm wrong someone..."
__________________
________
Lovely Wendie99
__________________
________
Lovely Wendie99
