HELP, Periodic clacking noise
Hey guys!!! Well I ordered all the gaskets and I'm going to order the tensioners tomorrow, wait till you guys see what I found!!! Top if the tensioner had no tension on the chain what so ever!! Just the bottom had tension, I'm on my cell phone right now, will post soon
Good luck with the tensioner job, you'll sleep easy once it's done.
98JagXJ8L (02-03-2013)
Yes i will sleep easy after this is done, Here are the pictures of how loose the top chain was on the RH Side, i just ordered the gasket set, and its about
$130 for both Tensioners RH & LH uppers but im still kind of shopping around because i heard i could order the 2000 Lincoln LS Tensioners and they are the same thing but cheaper?
either way i got to get them soon so i can get the job done, here are the pics!
And like you said Seconds away from disaster! As you see in the pics the top of the chain had no tension only the bottom had tension.
![](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/32321-help-periodic-clacking-noise-d339bc94-2700-449d-95a7-7867a538084d-1280-000000d1c5922694_zps13d3b0a7.jpg?dateline=1359934026)
![](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/32322-help-periodic-clacking-noise-1b596cac-7d72-4bb7-ba4b-75e1bdeadc71-1280-000000d1c9cb1d79_zpsb85845d3.jpg?dateline=1359934026)
![](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/32323-help-periodic-clacking-noise-4e2554ed-fe86-4b27-81f8-5de13d82e1b0-1280-000000d1ce2acbbb_zps2ccb3f38.jpg?dateline=1359934026)
![](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/32324-help-periodic-clacking-noise-b60745e5-1cdb-4321-9972-ae2ceda55608-1280-000000d1d337cee9_zpsc80fe5a7.jpg?dateline=1359934026)
![](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/32325-help-periodic-clacking-noise-4c03dc23-78a7-4326-8f51-b7d00a24daf7-1280-000000d1da713d86_zpsb88b4760.jpg?dateline=1359934026)
![](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/32326-help-periodic-clacking-noise-885c0ac6-aa4f-45ea-b4b2-021dd3cc9ac5-1280-000000d1dd6b2895_zpsb49d517c.jpg?dateline=1359934026)
98JagXJ8L (02-04-2013)
That's a worrying picture as you've definately got a metal tensioner in there. It is spring-loaded so should be extended anyway. In the picture you show, it's the bottom part of the tensioner that's the moveable spring-loaded part, so you can't 'pull it up' on that side of the engine.
On the other bank of cylinders the spring-loaded moveable part faces upwards, so that side could be pulled up.
You need to take these tensioners out & see if they extend under their internal springs. If tbey do extend under their internal springs, then you need to check the oil supply to the tensioners & see if that is blocked. The oil supply feeds into a central hole in the tensioner base at the bottom, between the 2 bolt holes.
The other possibility is that the chains themselves have stretched beyone the limits that the tensioners can cope with. Either way, this kind of behaviour from metal tensioners is cause for concern-because you've definately got the metal tensioners in there.
#30
How would I clean out the oil supply passages? What's a good method of doing this?
Also is it common for the upper chains to stretch before the main chains? I checked those and they are tight as can be, I'm a little worried now as I do not have the tools needed to replace the secondary chains.
Plus I'm down and out for about two weeks due to a knee sprain, getting out of bed is hard enough, :/
#31
Easy there. No need to panic.
As you already have the new tensioners coming, just replace them. This one you are showing is definitely collapsed (or not expanded). Could be many reasons why. My suspect are the bolts, but once you take the tensioners out, it will be clear.
The chains can not stretch as much as this, and the tensioner clearly looks like it's not expanded.
So,.....put the new ones in (with the correct bolts!), pull the pin, and see if they make the chain tight (I'm almost sure they will).
If they don't,......well it will be the time to rent some tools!
#32
#33
That's a good one. I was thinking the same, but I "talked myself out of mentioning it" (who could attempt the tensioners replacement, and be dumb enough not to pull the pins?).
But it definitely looks like the thing did not expand, and it sits just like the pin is still in. Worth checking,....who knows.
#34
well I can't lay here and rest with this stuff on my mind, I'm going to get myself up and take off the other valve cover gasket and post pics for you guys to see what I find in the other bank
#35
The worn VVT noise is normally treated by increasing the 'weight' of the oil. Try a can of 'Restore' oil treatment. If that eliminates/reduces the noise use a heaver oil at the next change.
A '98 MY engine came with the first generation non-spring assisted tensioners whose failure rate is legendary. Several very knowledgeable folks have advised that the engine should not be started again before the tensioners are inspected/replaced. I would take that advice as the penalty for a failed tensioner is a replacement engine.
#36
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
Finally Wobbled back into my room with my knee killing me also came an awesome feeling relief
i took off the valve cover on the (US) Driver side and tension was very tight on that one as pictured below. both top and bottom were under tenion.
![](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/32439-help-periodic-clacking-noise-4b50add1-1bac-47eb-9631-cb0016ee74d9-1113-000000caf2252502_zps82dc0c03.jpg?dateline=1360025886)
As i rotated Engine Via Crank Pulley... The (US) Passenger side Tension did its job and started to apply Tension on the chain... Both top and bottom were under tension. IT'S ALIVE!!!
![](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/32440-help-periodic-clacking-noise-586ef53e-8f86-4d37-a146-98522b710fe3-1113-000000caf65f1551_zps495d9352.jpg?dateline=1360025886)
As for the (US) Driver side it started to give a little, Is this how the tensioners work?
Im very relieved to see that they are both working, i just got worried on how relaxed that chain was, i'm guessing it's due to the position of the cams?
As posted Earlier by XJay8 he suspected the periodic clacking to be indeed the VVT Solenoids, So im going to try that thicker oil with a can of restore.
I wish the guy ho sold me the car had the paperwork showing the tensioners were updated. (as well as bolts)
With your guys excellent input i did not think twice when you all told me to take the covers off and check for myself.
Well the Valve Cover gaskets are on their way along with the Bolt seals, (Car needed them badly anyways) good thing i did not Order the tensioners for these ones are still good.
I Have to Give you ALL a good Cheers for giving me all this support and i have gained a lot of knowledge from this that will never be forgotten!![Icon Drink](https://www.jaguarforums.com/forum/images/smilies/icon_drink.gif)
Now i just have to search the torque specs for the valve covers
if you guys have any input on what oil to you let me know.
I originally was planning to put castrol 20w/50 with Lucas... Too Thick?
Might as well get input on this now being that the car does need an oil change.
Many Many Thank yous and CHEERS!!
![Icon Toast](https://www.jaguarforums.com/forum/images/smilies/icon_toast.gif)
#38
![Icon User](https://www.jaguarforums.com/forum/images/smilies/icon_user.gif)
#39
