HELP, Periodic clacking noise
#41
98JagXJ8L (02-08-2013)
#42
#43
Correct torque spec is 8Nm....whatever that is in Inch Pounds ;o)
Correct sequence for tightening is start from the c3enter in a diagonal pattern.
Before tightening down, make sure the mating surface is clean, the ruibber seal is in it's groove and give a wipe with carb cleaner and wipe dry.
These seals need no sealant added except at the mating face of the front timing cover.
A small dab is all that's required.
98JagXJ8L (02-10-2013)
#44
The tensioners shown are obviously the metal bodied ones, but I note the plastic chain guides are orange in colour. I was always under the distinct impression that the plastic chain guides on 3rd generation metal tensioners are white. Can these be in either colour ?
I understood the white denoted a higher quality plastic part, less likely to show wear over time. I know I am probably totally wrong in this, but could someone clarify for me as I'm thinking of checking mine as well. I have a late 2k 3.2 xj8.
#45
#46
Richy_Jsy (02-11-2013)
mikiep
12-20-2019 07:37 PM
baskervillema
10-01-2015 06:43 PM
