HELP!!! Whats the size (threads) of the crankshaft bolt. HELP!!!
Old 07-25-2011 | 02:26 PM
jimlombardi's Avatar
Hi
I found another thread on the crankshaft bolt information for removing the crankshaft pulley:
https://www.jaguarforums.com/forum/j...s-tools-51211/
Go to post# 19 (posted by member pd_regan)
"The bolts are 8mm thread so thats a 13mm head on the bolts in the pic, just checked my puller and their 84mm centres"
Maybe pd_regan knows the crankshaft bolt's length and thread size, try sending him a private message.
Jim Lombardi
Old 07-25-2011 | 04:33 PM
motorcarman's Avatar
The Crankshaft Damper bolt is a 16mm X 2.0 and socket to remove is 24mm.
I needed a 'tap' to clean the threads one time so I made one out of an old crank bolt.
If you cannot find a 16 X 2.0 tap or rethread tap then buy a new bolt and make one by cutting slots with a 'cut-off' wheel.
You don't state the reason for your request, but here is some info.
bob gauff
Attached Thumbnails HELP!!! Whats the size (threads) of the crankshaft bolt. HELP!!!-aj26_27-crank-bolt.jpg
RoyLittle0
05-25-2023 03:38 AM
Forcedair1
05-14-2023 04:28 PM
GordoCatCar
01-02-2017 02:10 PM
Gerard Radimaker
09-13-2015 11:33 AM
Quick Reply: HELP!!! Whats the size (threads) of the crankshaft bolt. HELP!!!
