hesitation
ok, i've already read smx's forum on this, but is this a common problem???
2 people said it already, an at 3-4000 rpm, its happenning to me too. car just hesitates. fuel line under the hood sounds like to rare of a problem for so many people with same problem....any suggestions???
i wud check the fuel pressure regulator vacuum line right side of engine beside the throttle body.. rightoff the regulator the vacuum line makes a 90 degree bend and in that bend it collapses over time cause vehicle to be too rich.. sometimes does not set codes.. unless if it is severe.
