HID Conversion the Cheap and Easy Way
To install the parking light socket in the housing turn cw.
hope this helps.
Hi Sean,
Thanks from a relocated Liverpudlian
1 knew I could count on you for an answer. Always read your posts
Any one got a head light lens with parking light receptacle?
To all the smart and great contributors to this forum a thanks and a smile ,its thanks to your posts I have become more "intimate " with my kitty! as opposed to intimidated !
The foglamp and head lamp link for the kit is the same one you just choose a different bulb number. Would be hard to see with a camera where I mounted the ballast for the headlamps. There is a small area, barely big enough to hold the size of the slim ballast when you pull out the headlamp, it's between the outer fender skin and the inner fender well. Look to the extreme right or left of the car once you have the headlight out and you'll see it. The foglamp ballast I just used the double sided tape and affixed them to the back of the metal bumper just above the foglamp and then put a zip tie around them for peace of mind.
WTB[NorthEast]: Driver door splash shield
convincor
10-01-2015 05:19 PM
Malihide
09-29-2015 03:21 PM
