high pinched whining noise from engine,
vincent661983 (01-21-2014)
yes, noise is continuous
serpentine belt was also changed 2 years ago,I doubted if it failed prematurely. I will looking around some other areas.
to Sean. yes, this winter has been harsh and it might related to cold engine start.
a separate thread I just opened, I talked about the battery drain. thanks
I would pull the SC belt and see what happens, then pull the other belt and see how it sounds. Obviously you can't run it for more than 30 seconds or so like that but it may narrow down the source of the noise.
Then while the belt is off, spin each pulley by hand, feeling for drag, rough bearings, and noise.
The following 2 users liked this post by vincent661983:
dsnyder586 (01-28-2014),
RJ237 (01-28-2014)
rachelstr
09-03-2015 12:59 PM
innzane
09-02-2015 10:08 AM
