High pitched noise from the top of the engine bay
It is most probably from the TB. The throttle motor is operated by a PWM signal which has frequency of about 300 hZ.
If you listen to this a 300 hZ audio sample (https://textmechanic.co/300Hz.ogg) you will find it similar to the sound you have.
Sixx Dogg
10-14-2012 06:55 PM
