Hood won't open
Guest
Posts: n/a
You actually have to remove the fender liners as your dealer has said and believe it or not, drill a hole for access, then stick a long screwdriver through the hole and actuate the latch. BTDT. There's at least a couple of threads on here about it with pictures showing exactly where to drill. Have to be careful as on the passenger side here in the US, you're drilling about a 1/2 inch from the positive battery cable. What typically happens is the cable end will pop out of the retainer on the latch.
It is a common problem. I have attached a link to a thread with pictures.
https://www.jaguarforums.com/forum/x...release-29427/
