Well it is a tight space. But I got the old hose off. And this is where I am at. I assume I have to move atleast the plastic coolant piece. Honestly, I didn't think this would happen before even starting it lol.
Split the new one and wrap it up with duct tape??????
Personally I would buy a NEW coolant outlet pipe (it comes with new seals) and replace it. It is made of resin and cannot be far behind the hose as far as deterioration is concerned.
They are cheap compared to a replacement engine. I ALWAYS replace the thermostat tower (if it is resin), bypass hose and outlet pipe all at the same time.
That's the best advise. When I took mine apart, all resin pieces were crumbling. So, for the same labor and cuts on the wrist, new hoses, TST, TST tower, crossover, stumpy, belt, belt tensioner, and water pump.
Many of those parts have been changed already. Anyways, I'm scared to drive it because I can't get the clamps to fully retract. Hopefully that makes sense to you guys. Either way, the clamps are on correctly. I'll post a pic shortly.
In my haste I did not order a by-pass hose when I did the outlet pipe & tower etc. A basic radiator hose cut to size from O'Reilly's fit the bill. Also broke one of the coolant vent lines to reservoir/the stiff plastic ones. W/ the help of a little JB Weld,super glue & proper whiskey we're leak free w/ optimal cooling lol.
PS :
What were these guys thinking w/ all the damn rigid plastics in the hottest area of the car ?! lol
PS :
I can actually understand the ideas... Just the execution could have been a lot better!
Very true, this is temporary until I replace everything that's brittle. Also factor in 100 degree FH heat coupled w/ 95% humidity. I think I did well, considering my BAC was in the high double digits lol.
Touche' sir lol !
We'll see if I cut it. Still, thanks for the response.
There is no short cuts to a fail safe systen....take Motorcarman's advice!
The collector pipe is prone to spring a tiny leak due to heat related ageing of the plastic.
I replaced mine same time as alloy thermo tower six years ago and nary a leak ;o))
Ok, I'll change it. It's easy enough. I drove it yesterday, no leaks. Of course, I'll keep an eye on it.
