how-change-knock-sensor-jaguar-aj27-engine-faq-45963
Can someone repost this guide or send it to me? The pictures are not opening. I have tried different computers and web browsers without any luck.
Also, any advice on the following codes:
PO300
PO305
PO316
PO332
PO357
PO1000
Thank you!
PO300
PO305
PO316
PO332
PO357
PO1000
Thank you!
It's not you. The link works fine but pictures are gone.
While we could post the diagnosis for your codes you would be better served to down load the JTIS file available in the sticky above. It has all the codes in a chart with the suspect issues listed in sorta order of frequency.
romajag (05-10-2012)
