How to change a Knock Sensor on a Jaguar AJ27 Engine FAQ
#41
I have had it happen at both Valero and Citgo.
Since I live in Texas there is no consumer protection. The gas station will blame it on the truck company and the truck company will blame it on the refiner and on and on.
They caught one chain here and figured they stole millions so the gave them a fine that was a pitance of what they stole.
It can happen at any station so always be wary if you start getting poor performance or codes about 10 miles after a fill up.
Still on the upside, they always offer to sell octane booster additives when you fill up.
#42
#43
Follow the wire back from the attached clip on the thermostat housing, about midway between the intake manifold and cam cover you'll see where that wire ends with a torx bolt showing. Thats it.
scarbro2011 (11-14-2015)
#44
Just to clarify, the cheaper knock sensor used in this write up is a OE knock sensor for a 2005 jaguar xj8 4.2 liter v8 and the plug is the same other than longer wiring correct.
For those of you that did install this alternate knock sensor. Can I get an update on any problems or its performance?
Thanks you
Thanks you
#46
David, your pics in the 2010 original post have vanished, any chance you still have them and can repost? If you need a hosting location, email me with the pics and I'll get you the link to where they're stored on our mediafire ftp area. Didn't see any contact method for you in your profile, else I would have PMd ya.
#48
Hi
I copied one of the photo image website addresses and was able to get on DavidN website (Frankfurt, Germany). David's website (Water Skiing) has a Photo of David.
I sent David an email from his website, asking him to see if he can repost the photos of the knock sensors for this DIY thread.
Jim Lombardi
Jim Lombardi
mrlovt (07-04-2012)
#51
Hi
I created a Knock Sensor DIY PDF (16 page) file from DavidN post# 1 and post# 2 and also included Knock Sensor location information from the JTIS21 shop repair manual.
Here is the weblink to the PDF on my mediafire account:
Free Cloud Storage - MediaFire
Jim Lombardi
Jim Lombardi
OldMike (05-08-2013)
#52
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
I own a 2007 XJ8 woth 90K miles. I hear the knocking/gurgling noise during acceleration from stop. I have determined that the knock sensors are at fault. Would the posted photos and instructions be the same for the 2007?
Any help would be greatly appreciated.
Other than this issue the car is a dream to drive.
Thank you again!!!!
Thank you again!!!!
#54
Hi
Jim Lombardi
Jim Lombardi
#55
After changing a knock sensor on my 1999 VDP (I had used a code reader to determine the problem w/a "restricted performance" message), I am still having the issue and my code reader is identifying the knock sensor as the problem. My question: Did I screw up by using a magnetic pick-up tool to position the sensor on the stud on top of the engine? Is the sensor that sensitive?
#56
#58
Tim
Use this weblink to PDF file (on my dropbox.com account) that has the photos in it (pages 3 thru 16):
http://www.mediafire.com/view/?oss71axa467vsj6
Jim Lombardi
Jim Lombardi
#60
