how to check camshaft and crankshaft sensor
Hello i want to check the cam and crankshaft sensors with a multimeter . Now ive read some things about reading between 1 a 2 volt ac when starting now is there anyone who can confirm this ? And can you read it when idile ? Thats what ive done did it 2 times and crankshaft gave me first time a 1,4 /1,5 reading and second time a 2,4 reading. And the camshaft sensor both times a 0,1 /0,2 reading when rev up it goes a bit up . If someone has some info about this let me know im checking this because the car boes not start up so good sometimes and it holds back when driving around 140 kmh and also when i use kickdown at low speeds. Ive checked fuel pressure and other things but they are ok .
Maninahat98 (01-18-2014)
RoyLittle0
05-25-2023 02:38 AM
KarimPA
09-12-2015 08:15 AM
joesoap
09-10-2015 01:09 AM
KarimPA
09-03-2015 07:32 PM
