How do I get to the windshield washer pump?
I've got a (new to me) 2001 XJ8. Windshield washer worked, but shortly after we got it, it seemed that something wasn't right. Spray worked on on some ports and dribbled in others. Wife had it on the road last week and it wouldn't work at all. I just finished washing and detailing and pulled the hose at the cowling. I put a compressor on the line to the wiper and it's clean (i saw mist at all four points). I tried the pump again to see what I had at the nipple and all I got was some residual goo that dribbled out. I can hear the motor running but it doesn't want to push the gunk out. I imagine its some kind of residue that formed in the tank and has gotten pulled into the pump - figure if I can get to the pump I can disconnect the hoses blow them out and clear the system. Any other ideas I'm all ears.
Never mind. I'd traced the feed line from the reservoir to the firewall (hose turned from black to red) and a visual down through the cowling didn't look promising. After checking out what the pump looked like, it wasn't hard to find the pump under the top cover plate. I suppose the hoses all attach behind the "Trico" cover plate, but it didn't look like much fun to pull so I just pulled the hose on the cowling used a syringe to back flush and started running the pump. It took about 5 minutes of on and off again attemps and back flushing, but the primordial ooze that had formed in the line eventually made it through. Any ideas on what I might be able to add to the reservoir to help dissolve and clear out would be appreciated.
Scuttle=Firewall
My screen wash tank and pump are at the front of the car behind the RH headlights, and I thought they were there on all models? I had to dismantle most of the front wheel arch liners and under tray to get at it, and will have to go through it all again soon as my tank has begun leaking!
I need to get hold of my own air compressor at some point though, you just reminded me.
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Scuttle=Firewall
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
mikimogo
09-22-2015 08:09 PM
mikimogo
09-14-2015 08:34 PM
1964Daimler
09-09-2015 11:28 AM
