How do i open the coolant cap?
Just replaced the 90 degree coolant hose that goes into the thermostat, now it's overheating. Trying to get the air out and the reservoir cap just keeps spinning. Is there a trick to open the coolant cap on a 2000 XJR? Or am i retarded. Can someone suggest a way to burp the system, just noticed i drove it overheating for 3 or 4 minutes, car doesnt give you much of a warning, just a tiny red light.
Any suggestions?
Any suggestions?
There is a large port used for bleeding the coolant system. It is on top of the engine oversized Allen wrench needed (I used a big nut to get it open). Suggest getting the JITS manual it outlines the procedure. Make sure both your fans are operating when the engine is overheating.... not sure what is up with your cap.
abonano
25
09-25-2015 10:43 AM
hen555
09-07-2015 11:13 PM
