How do I open the trunk to my Jaguar if the battery is disconnected?
Guest
Posts: n/a
How do I open the trunk to my Jaguar if the battery is disconnected? i was restarting the computer so i unplugged the batterey, but the trunk locked now i cant open tip said he trunk what can i do. The dealership said locksmith, and the locksmith said dealership[/align]
RE: How do I open the trunk to my Jaguar if the battery is disconnected?
Two options: Positive terminal stud (under insulator), on firewall under the hood - passenger side; jumper cables (positive to the terminal stud, negative to clean bare metal anywhere), presto, power. Or, remove license plate, holes under it on trunk lid allow thin long screwdriver to trip the boot latch.
________
1999 XJR
________
1999 XJR
It's above the right front top shock mount about 6" and to the rear about 6" and about 5" from the right front fender. There will be a thick electrical cable leading to it and the stud and connector is covered with a rubber cap.
Doug
Doug
Ziggybeben
08-30-2015 02:09 PM
Andrew McVey
16
08-27-2015 07:21 PM
