how do i remove the 6x9 subwoofer from rear deck?
Old 02-12-2014, 12:31 AM
grandell's Avatar
To remove the bottom seat, you need to remove the heel panels first, then undo the two bolts. It should slide straight out, but if you have heated rear seats watch out for the wiring.
Now you should be able to see all of the screws underneath the seat back. Undo these, and the seat belt bolts. Before you try to lift the seat up, carefully remove the plastic clips from the top of the seat, where the seatbelt goes through. These break VERY easily. Once these are off, you should be able to lift the seat back up, feed the seatbelts through, then remove the seat.
The following 2 users liked this post by grandell:
dboydman86 (02-16-2014), tomsfirstjaguar (08-02-2016)
dsnyder586
04-04-2019 02:38 PM
FrickenJag
09-25-2016 08:00 PM
AL NZ
09-04-2015 08:39 PM
davidladewig
09-03-2015 06:32 PM
Joey T
09-03-2015 05:31 PM
Quick Reply: how do i remove the 6x9 subwoofer from rear deck?
