How do the rear license plate lights work?
I have a problem where the left license plate light works, but only when the trunk is slightly open. When it's closed the light goes out. I am assuming that there is a microswitch, or a tilt switch somewhere. Could anyone tell me which, and where it is?
The right hand light works fine. So it looks like there are two switches, one for each side.
Thanks in advance!
Thanks in advance!
The operation of the licence plate has nothing to do with the trunk being open or closed when the headlights are on. Mine stays on in my xj8 when the headlights are in regardless if the trunk is open or closed. I just checked.
Sounds like a loose/rusted/corroded bulb socket or bulb.
Since these are exposed to all the crap that comes out from under your car, they can dry out and crack over time. Ever look at the stuff/dirt UNDER your licence plate? Most people miss that.
johnleavitt
09-23-2018 09:50 PM
