How to fit a double-din nav radio into a 98-03 x308 XJ8
#61
Youtube is probably a good place to start, it's been done plenty of times in other cars.
First thing to do on your car is measure the hole the radio fits into, this will tell you how big your tablet needs to be. Then wire up a power supply, and get yourself an app that can automatically manage functions like turning on and off when you turn the car on and off.
I think the DIYMA forum will have LOTS of info as well
#62
It appears I owe you an apology, you are in fact correct about the amp in 2000+ cars. I was using the wiring diagram from the 99 model, and the Premium system is very different.
The 2000+ cars use an ainet linked system, the same as the XK's, where the cd stacker is connected to the amp, rather than directly to the headunit.
This puts my headunit upgrade on the back burner for a while until I can do a proper upgrade, rather than just swapping to a premium unit and trying to hijack the line out
#63
#64
Alpine - Digital Media Receiver - iLX-700
Alpine iLX-700. Double-DIN. iPhone and Apple bla bla bla. However:
Look at the pictures! If that is shallow enough to fit in an x308 dashboard, it could make upgrades a lot easier.
- Chassis Size (W x H x D) mm: 178 x 100 x 75.5 mm
#65
To AlexD:
Pardon how much later (than your post) I'm asking this here.
The radio cavity opening in my X308 XJR radio frame is 3 3/4" high. A 7" display is about 4 1/4" high including the frame. Is the display in that picture smaller than 7"? Seems like a lot of extra room to spare, like 1/2"?
I'm trying to get me a 7" display in my XJR (yeah, I said "display" and not necessarily a two-brick dual din...), but the OEM radio frame doesn't give me enough vertical room.
Thanks ahead for the info and regards,
Reinaldo
Reinaldo
#66
I finally have the answer to this dilemma that's given me so much pain, and which turns out to be all just because of stupid assumptions in my part. Ever since I saw pictures of TFT installs on an X308 I've kept assuming that they were 7" displays and nothing less. If those pictures that show the display in a very comfortable fit were making less and less sense during my painful efforts with my 7" project, I should've stopped and re-considered the facts, including the possibility that those TFT displays WERE NOT 7".
Finally, in reviewing this post once more, I came across the model # of the radio he was working on and, of course, and making all the sense in the world, it is, indeed, a 6.1" display and not a 7" display, clearly explaining not only why this radio here fits with room to spare, but also some other fancy X308 installs that I've seen in the Internet that now I realize they must also be 6.1" displays.
Too bad, but guess what's in my X308's dash nowadays...yes, a single din DVD receiver with a 7" TFT display. Of course, it wasn't easy by any means and I did have to do a small visual alteration to the bottom edge of the radio frame, a small price to pay for the joy of a larger display.
My old 5.2" display radio still shows on my XJR pictures gallery, but I'll be soon replacing them with new ones showing what may just be the only X308 in existence with a full 7" display. A nice complement for a very special ICE set up.![Icon Playing](https://www.jaguarforums.com/forum/images/smilies/icon_playing.gif)
Cheers,
Reinaldo
Cheers,
Reinaldo
#67
If by "hijack" you mean removing the ainet cable from the car, why would you do that? (unless I'm grossly misinterpreting you here). On my 2002 XJR (Alpine "premium" system) I simply left the cable in the car and just added 4 pairs of new RCA cables going back to the trunk.
Cheers!
Reinaldo
#68
by "hijack" I mean I made a patch cable that goes between the headunit and ai-net cable that bypasses the cd stacker audio channels and runs to rca's, so I can plug my ipod into it
#72
The following 2 users liked this post by grandell:
King Charles (03-28-2017),
Roldano (04-18-2019)
#75
Yea you can't go wrong when you see the Alpine name, even after all these years they're still top quality.
Not sure if this list has been updated but it was @ one time car audio gospel lol.
Car Audio Brand Ratings- Is this Brand Any Good? The Good, Bad and Ugly List
#76
#77
I had Alpine grills, but then I swapped the entire interior from a wreck into it, which had had the premium stereo, so now it has Harman Kardon grills.
Of course, I'm running Arvus speakers, DLS and Sundown amps, RE sub, and an Alpine processor... so it's all moot really :P
It looks good & sounds awesome, that's all that matters in the long run lol.
#79
dragging this back from the depths...
there's a new Alpine unit that looks interesting. 7" screen, but fits into a single din slot at the bottom!
Alpine
![](https://images.crutchfieldonline.com/ImageHandler/scale/978/978/products/2015/45/500/x500iNEW967-o_angle3.jpg)
Alpine
https://www.jaguarforums.com/forum/a...cement-155873/
#80
