How long until emission computers gather enough information?
Hi all, if you haven't seen my posts lately, I bought a 2000 XJ8 which had a few problems. One of those was a discharged battery. Obviously to recharge it I needed to disconnect it and take it to AutoZone, so this reset the computers.
I drove the car 250 miles and the catalytic system data is still available. Neither is EVAP. Both show up as "X" on the vehicle reader. So I can't pass the smog check. How long do I have to keep driving until those systems show up?
I already did 1 and 1/2 tank of gas and still nothing. Around 30-ish gallons of fuel. I also drove the car all weekend like suggested, on the highway and city. I did around 5 hours on the highway straight, then idled for about an hour a day for two days, then drove in stop and go traffic for about 3 hours, then drove in the city for about a couple hours a day for two days in a row. Trip A on the message center says "252.3". Should I make it to 300? The smog guy today said it might not even work with 400 miles.
Received 2,831 Likes
Hooli (04-04-2023)
My car throws an occasional P0420 check engine light for the left side cat. Drive a few tanks of gas and it usually goes out on its own, most of my driving if highway.
So the cats may take quite awhile, but all I have is mo own personal experience...when I've reset the battery and put any of my vehicles into test mode again, they've all either cleared properly or thrown a new trouble code within 1 tank of gas.
ericnunez (04-04-2023)
Sorry haha. I am probably not making myself clear. There are no codes because the system, Cat, has not gathered enough information to show any. The systems cannot show codes if there is not enough information to determine whether or not there are any errors.
again the answer is a while if you just drive it. 2000 means only evap can be not ready they don't care about ccm. do the monitoring set conditions for a p0420\430 every time you use the vehicle
http://jagrepair.com/images/AutoRepa...J27%201999.pdf
Lord Donnington
02-22-2020 09:45 AM
