How many quarts for the trans??
RE: How many quarts for the trans??
ORIGINAL: BRUTAL
a rule of thumb on pan drops and filter change is 4, 5 if you go drink a beer and let it drain longer of if youre poky
can any one verify this? TIA Alex
ORIGINAL: 1st jag
I was told that if you hook up andgo thru the oil cooler lines and remove "ALL" the oil out of the tranmission, that it can take as much as 14 quarts!![sm=sick.gif][sm=sick.gif]of really expensive trans fluid,
YES ALEX ILL TAKE 14 QTS FOR $50 PLEASE....(SAY IN YOUR CLOSEST JEPARDY VOICE)
IF YOURE DROPPING THE PAN 4-5
IF YOURE DOING A SYSTEM FLUSH 12-14
DRY SYSTEM CAP. IS 12
ORIGINAL: BRUTAL
ORIGINAL: BRUTAL
ORIGINAL: 1st jag
ORIGINAL: BRUTAL
and install only 4 to 5 quartsof trans fluid when the capacity is 12 quarts? so you would
have aprox 8 quarts of old dirty trans fluid? UGHH!
cause if you replace33% of the fluid every couple years youre do 3xs more than most ever do.....but its up to you. evry other oil change I drain 4 qts out and refill, every other year i drop the pan and put a new filter in, and in a 120k miles the inside still looks brand new. Besides to do a flush, you really need a machine to do correctly, and either way its messy and stinks like cat ****
ORIGINAL: Markus
Nice pix, Brutal! Clever chap you are - headlight conversion is really inventive! Thought about marketing a kit for it?
