How much fluid is enough and what kind?
Trying to get things ready to change my tranny fluid. I've read several posts but want to make sure. I have seen its a 6mm hex for the fill plug. I'm guessing I need a hand pump?? How do I know when the level is right? Is it like checking a rear differential?
Without draining your torque converter, which you cannot do, it will take a little over 5 qts. With the car level on jack stands or a lift. Fill until ATF drains out the fill hole at about 120 degrees F. That temp is about where it becomes uncomfortable to hold your hand on the bottom of the transmission pan. Move the shift lever slowly through the positions several times with the engine running.
I hope that you haven't fallen for the 'only use Pentosin' mantra. Ford now has formally stated that MERC V meets the LT71141 specification as has several other brands.
All the links you could ever want: https://www.jaguarforums.com/forum/x...uestion-78968/
