How to program Keys? (not the remote FOB)
So, I have a buddy that's a locksmith, but he doesn't have the adapter to cut TIBBE keys...bummer I thought...well I guess not![Icon Clapclap](https://www.jaguarforums.com/forum/images/smilies/icon_clapclap.gif)
With a set of precision files I cut 2 keys to my original key in about an hour of spare time. So, now I have 2 spare keys that open the car and turn the ignition but will not start the car.![Icon Banana](https://www.jaguarforums.com/forum/images/smilies/icon_banana.gif)
My buddy says that he will program them to the car for me, but I read somewhere that it's possible to program them without some kind of a computer. Anyone have an idea what the procedure is? I'm not asking about the Remote/Fob programing but the actual immobilizer/transponder key coding.
As previously mentioned, you need two programmed keys to be able to add more keys without using the dealer computer. And you have to programme them as a set.
Your buddy's method may be different, but the typical cloning procedure used by locksmiths is different from dealer programming. It essentially creates multiple electronic copies of the one working key. The SLM only thinks there is one key because all of them have the same electronic signature.
BTW, source and cost for the key blanks?
This does not work on later cars.
I suggested previously that a good strategy is to do it in the dealer parking lot. If it works, you drive away. If it doesn't, go in and see the nice service advisor.
No reference. But, it is here somewhere. One of us is going to have to search for it ... guess who
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
As far as I know, the only cars that you can have '2 keys and add a third' is the X200 (early S-Type).
We discovered this when my buddy at the dealer had a Ford Pick-up and it was documented to work for his vehicle. We had an S-Type in for 'adding a key' so he thought he would try the 'turn each master key on and off and insert the third'.
It worked because the car is very similar to the Lincoln LS.
I don't think I ever tried on another Jaguar but I don't think it will work.
bob gauff
bob gauff
plums (01-20-2012)
Today my buddy came over and programmed all the keys to the car
so I have 3 keys now. He also told me he bough the adapter for cutting TIBBE keys so I guess I wasted my time doing it by hand....oh well...
We also checked in all his manuals and apparently there is no way to add a key to the x308 without a programming tool. He also mentioned that you need at least 2 keys just to program any key to the car. So, if you only have one key and you loose it, you will need to get two keys just to make it work.
Hopefully now I can install a remote starter in the next few days![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
If anyone in Chicago-land needs to get a key cut/ programmed ill put you in touch with him.
The X200 (early S-Type) needed 2 keys MINIMUM to program keys. You could not choose 1 key when the 'configure keys quantity' message was on the screen. The MAX quantity is 5. Other models you could choose 1 key minimum and 5 keys maximum. The X308 can be configured to accept 1 key with the WDS or IDS.
The X200 can be 'fooled' into thinking there are 2 keys by wrapping the only correct key in foil and get another (customers) key held close to the wrapped key during programming. When the second key is requested, you quickly unwrap the correct key and program.
I don't know about other programmers minimum requirement.
bob gauff
bob gauff
plums (01-25-2012)
Lateral thinking award of the year
Someone who does it often could always just keep a junk key in the toolbox for the job.
Apparently, if you have two keys, it will let you do it in almost the same way as doing the fobs. It's turn this, click that, insert key blah, blah.
No reference. But, it is here somewhere. One of us is going to have to search for it ... guess who![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Jzar
09-27-2015 02:55 PM
zdrapec
09-25-2015 05:49 AM
