How to Remove Door Mirror Covers?
I've done a search here and can't find the information I'm looking for. Does anyone know how to remove the coloured plastic covers on the door mirrors (I want to sand and repaint them), or if it is even possible to remove those without removing the entire mirror assembly. Appreciate any input.
badger2196 (04-02-2015)
Received 9,010 Likes
Was reading of your plight, and belatedly realized (duh!) that I had a broken mirror out in the shop.
Went out and attacked it with diverse implements of torture.
The following pics should tell the story.
Basically you have three tubular plastic pegs that slide into split collar sleeves in the mirror body.
You've also got a large plastic clip at bottom center and a smaller one in the obtuse corner.
My mirror had been broken for who knows how long, so there was some rust on the metal split collars. One of my split collars was also broken loose from the mirror body. That was from the original mirror damage, not from my efforts today.
I won't claim it was easy to remove the back ... it actually fought me pretty hard until I sprayed a little WD-40 on the pegs. I used the widest of my plastic trim removal tools to work the back off.
Try to work it off as evenly as possible, once you've got the two clips released.
Just take a little care and you'll be OK.
Hope this helps,
retro
![Name: 003_zpslhkg06yq.jpg
Size: 89.8 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/155247d1501210991-how-remove-door-mirror-covers-003_zpslhkg06yq.jpg)
Hope this helps,
retro
![Name: 001_zpscmhobbe2.jpg
Size: 104.1 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/155248d1501210991-how-remove-door-mirror-covers-001_zpscmhobbe2.jpg)
The following 6 users liked this post by retromotors:
al_roethlisberger (04-07-2015),
badger2196 (04-04-2015),
bigcat777 (04-08-2015),
deancantrell (04-03-2015),
Jhartz (04-03-2015),
and 1 others liked this post.
I am so glad you posted this thread, as it is very timely for me as well. Both of my mirror covers also need to be removed and painted, and I was of the impression that they were attached from the interior and required the mirrors being removed.
So this is great news that they can be removed from the outside.
badger2196 (04-08-2015)
99xk8guy
06-05-2023 06:28 AM
