How to remove the trim from centre console
Old 08-31-2013 | 09:02 AM
EscapedApe's Avatar
Default How to remove the trim from centre console
Hello all,
I've just purchased a XJR 2001 which has a wretched Nokia phone holder "hooked" into the centre console next to the gear selector (see pic below).
I want to remove but have no idea how the wooden panel is removed to get to the mount the phone is on. Any tips or links to how-tos would be great :-) (I've just spent the last hour Googling but haven't found a guide for the XJR circa 2001)
...even more bizarrely, the former owner still actually had an old nokia he used.
Hmm, I wonder if I could get a bluetooth adapter to work with this setup...
Regards,
Troy.
Attached Thumbnails How to remove the trim from centre console-centreconsolepic.jpg
Old 08-31-2013 | 10:05 AM
motorcarman's Avatar
You need to pry the gearbox selector lever surround 'straight up' with plastic or wooden prying tools. I use windscreen plastic tools but something like a popsicle stick will work.
You will break some or ALL of the plastic mount pegs in the surround and the switch bezel.
The console veneer panel is held down with 4 screws on a plastic plate. (the plate that retains the surround bezel)
Lift the rear of the veneer panel near the ashtray and lever it away from above the radio/climate control panel. It has a plastic 'tongue' that fits in a slot.
bob gauff
The following 2 users liked this post by motorcarman:
EscapedApe (08-31-2013), Maninahat98 (09-01-2013)
Old 08-31-2013 | 09:36 PM
EscapedApe's Avatar
Thanks Bob! That was a piece of cake...and I only broke 1 tab
...although, I must admit, I did find a youtube video showing how to do this for an XK8 using two credit cards. I also saw the post in one of the forums guides too but couldn't find it again to say thanks :-(
Troy.
Rivguy
12-04-2020 08:55 AM
Nigels420G
Mark V - X 420G
09-17-2015 11:29 AM
280zx-turbo
09-10-2015 07:29 AM
1964Daimler
09-09-2015 12:28 PM
XFR_Gold
09-02-2015 01:24 PM
Quick Reply: How to remove the trim from centre console
