How to replace a fuel pump jaguar xj8 2000
The instructions are for a XK8 but should be near the same http://www.gusglikas.com/AutoRepairFuelPump.htm
Thanks,
Bill
Thanks Gus. I was observing my mechanic while he was trying to remove the tank. He was trying to pry it from the bottom without detaching the fuel line leading to the fuel inlet (where you actually put gas in). Thank God common sense kicked in for him. He decided to stop and wait for his brother who is the actual Jag expert. I did send him a copy of your procedure. Hopefully he reads it and consults with his brother. Thanks for you help.
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Thanks dneider. The tank is coming off today unfortunately I wont be there to take photos of the procedure. Darn!!! I also should have gotten the fuel pump online as it is much more cheaper. $210 for a new one at the dealer. Double darn!!
Thanks, since I already purchased it, I now have to decide what I should replace when they start inspecting the knocking noise. Hopefully it's just the water pump. I did ask them to inspect the tensioners to see if they are the new ones. I had to give them a photo of the tensioners so that they can compare.
If *insanity* is indeed trying the same thing whilst expecting different results, i would again suggest the whole job is a 2 hour undertaking if you just pull the pump only, up through the rear package shelf....no undercar, no tank removal, no grease or dirt.
Can't tell you the number of dangerously mangled fuel lines I've seen under rear of these cars, since ignorance and a larger hammer conquers all....
FYI, I pulled my tank with lines in place, and yes, they got mangled. I was fortunately able to bend them back into shape and use them still. It's been almost a year and no leaks. I would highly recommend using the line removal tool shown above (GUS's link I believe) and pull the lines first. They will be a lot harder to replace if destroyed.
I don't know about other cars, but on my 1999 XJR, there is no possibility of doing this. The panel over the tank is solid metal, excepting for where the speaker is mounted, and that does not line up with the fuel pumps. Sure would have been a nice design implement if they HAD done that... Maybe on the '00 XJ8 it's different? See attachment for photo of mine.
Bloweraddict was referring to his solution - cutting a hole in the metal below the parcel shelf - outlined in his post below. Certainly sounds like an easy alternative.
https://www.jaguarforums.com/forum/s...922#post234922
My tank finally came off and all I can say is that it's a task that requires 2 or 3 people to accomplish. My mechanics did raise my VDP to remove a bolt/screw from inside (behind the seats). They also disconnected one of the trunk support rods (closest to the gas tank fuel insert) as well. They also did a great job not shredding any wires. I highly recommend OEM factory fuel pumps. Works like a charm. We got the car to run!!!!
. Now all I need to do is fix the engine knock
![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
I ordered a replacement pump here: https://www.jaguarlandroveroemparts.com/
My brother did NOT want an after market pump. It is absolutely the heaviest fuel pump I have ever had in my hand.
Very strange thing happened when I placed the order, long story. Local Jaguar dealer told me that the pump would cost $580. The place I used on line had it listed for about $385. I ordered the part Friday, on Monday they charged me $274 which included $18 shipping. That blew me away.
Besides that, I made a mistake and believed a YouTube video replacement where a guy "tolikz05" claimed that there was NO NEED to disconnect the fuel lines under the car. Well, I now have a leak that I need to investigate. Grrrr.
