How to use Sport mode ?
Nope. Ot was never updated along the lines of the XJ. Jaguar always ordered the cheap version of the tranny. Around 2005 the box received some major alterations and changes including a different valve body with less wear, not retrofitable though.
3timejag (08-18-2017)
Sport mode raises the shift point in D to about 3000, unless you floor it when it will shift near redline. But if you use the j gate you must decide when to shift It will still take off in first but will not upshift beyond the gear you have selected.
If you shut off traction control you are liable to spin tires but it will not help acceleration.
Flooring it in D will probably be as good as it gets, but you don't have a dragster.
Lastly, be aware that the A drum is the weak point in the transmission and stressing it by calling for max from standstill may hasten it's failure. And never rev in neutral and shift into gear.
When I shut off traction control I don't peel out. Not that I want to. Is something wrong if it doesn't peel out with traction control turned off?
#30
![](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
Always fun to horrify some "kiddie" when he gets blown away by an old geezer in an "old man's car". The look on their face ( the WTF was that ? "look") is always hilariously the same
#31
Well when I received the car back from a full transmission rebuild, it was in sport mode. I've left it there & must say I enjoy it ! Only thing is the kick down while in cruise control on hills etc. a bit more noticeable.
#32
