How to verify an Nikasil engine was replaced by Jaguar
Received 2,190 Likes
A well taken care of nikasil block is stronger, lighter, has less friction, and produces more power over any lined motor theres a reason they are used still today in cars such as twin turbo porshe, ferrari, lambo, among most of the motorsports. the main problem was with high sulfur content but thts a thing of the past. theres a reason you hve to use diamond coated tools to bore out a nikasil block only thing hard enough to do it
Rlover (06-07-2012)
if it makes u feel better have jag do their test on it to see how its running mine was a very low mileage car it sat through the bad years of high sulfur i had it tested when i got it and it was running better numbers than I have seen on alot of new engines. I dont burn any oil, great power, starts right up, nothing out of the breathers and its leak down numbers were amazing.
rusty37
06-07-2016 04:43 PM
