How's this for coolant leak
Been searching for a hidden leak for some time now. I've pressure tested twice and found nothing. Leak isn't consistent, I've got a reminder set up on my phone for Saturday mornings and with steady driving routine, level can stay consistent for a month or a week without having to top off. I get a call from wife last week that there was smoke coming from under the hood. I take her another vehicle and first thing I look at is coolant level - it's fine. As expected, I start it up and get nothing so I just drive it home and back it into drive (first time I can remember) figuring I'll search this out and take care of front shock bushings I've been putting off a few weeks. Car is parked and hasn't been started up since I put it in the drive. I come home for lunch the next day and I notice a steady drip from the front end of the motor, puddle is about 6" in diameter, which is puzzling (not what I'd have expected from the drip I was seeing over a 24hr+ period). I check it again when I get home later that day and puddle isn't much bigger, has started to evaporate and there's no drip. Next day nothing new, no drip and no puddle. Yesterday I jack it up and start the bushing job and about halfway into the first one I've got my head in the wheel well and I notice a small puddle - sure enough the drip is back. I finished up the bushings and start looking and I've got a small puddle and no drip. Nothing so far today, but I'm leaning toward the leak being a bad bearing seal on the water pump, figuring it's breaking seal or holding it somewhat randomly (explains inconsistency I'm seeing). Any thoughts? I'd looked at WP before but with no visible leak during pressure tests and fact it and rest of front end coolant components were upgraded and replaced as part of timing, and tensioner replacement few years back had written it off.
Could be any of those things, but check a/c condensate. A/C can cause condensed water to gather on parts nr the rear of the engine. This could be the "leak." Jacking the car up could have allowed any remaining water to find its way to the drip point causing what appeared to be a second leak. Worth a look.
Already have the new aluminum Thermostat tower, new thermostat, new cross over, water pump, and all hoses including one of the poly coolant lines from radiator to expansion tank replaced when I did a full timing replacement a couple years back. Hoses were first thing I checked
OK now I'm truly baffled. Car hasn't been started since I parked it last week, and concrete has been dry since second drip evaporated Sunday. This morning I grab newspaper and turn around to the same fresh 6" puddle. No active drip, but it definitely leaked overnight with temps just below freezing.
Google or search here: replacing thermostats or just thermostats.
Weep hole is a bleed hole that should be at the top *12 o'clock* position when the thermostat is replaced, if it is on the bottom, fluid leaks out.
I still think you have a bolt (probably water pump, but maybe thermostat tower and housing) that is not torqued or has a tear in the gasket. The leak is under the front engine dampner, ne?
IME, Dexcool (and other newer coolants) can be a real PITA when it comes to small leaks. Often times the goo they're made of solidifies around the leak and it'll stop, then eventually it gives way and you get a leak again. By way of example - and maybe something to check - my Audi has a tiny leak at the seem between the radiator core and end tank. Sometimes weeks or months go by with zero loss, then suddenly I'm a cup or two low in the reservoir. When it's not leaking, I can see a small trail of goo from where the leak is. When it stops leaking, the goo has broken loose and the radiator is clean again. It's like a glacier breaking off.
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
I figured that was what you were referring to. All the work has been done for a while so whether up or down I can't confirm. I'll check it when I get a chance. I could see that allowing fluid to flow back to WP but not cause of the leak
OkieTim
09-08-2015 04:48 PM
