I bought another x308, 99 XJR, mods incoming.
I still have my 2000 XJ8, which my son is driving now, and I had been looking for a replacement vehicle when this XJR fell in my lap. It's pretty stock and well maintained ( actually I maintained a lot of it, I know the PO well and I'm the one who got him interested) so I don't have much on the repair front, but I have a lot of things that I did to my XJ8 that I really miss plus some things that I just want to do.
Work / mods list
(Will be updated to links as I go)
Done or parts-in-hand
Brake job - Hawk HPS front pads Porterfield R4S rear
Floor mats (Automatstore, classic loop)
Stainless rear exhaust
Spark plugs
Key fob buttons (last time)
Aluminum gauge rings (swapped over)
Bluetooth add-on for stock radio (A2DIY-JAG98)
Smoked LED corner lights
Shock bushings
Realgauge (Coolant)
Changed fuel cap holder from magnet to post
Bosch intercooler pump
Repair broken glovebox damper
Shift knob
Ultimate aluminum pedals (accel & brake)
Future, planned
New intercooler (i'll probably make/re-purpose one)
New wheels and tires
A bunch of LED's interior and exterior
Intake tube / filter
Shocks
Upper supercharger pulley
Goodridge braided lines
Replace headliner
Work / mods list
Spark plugs
Shock bushings
Realgauge (Coolant)
Shift knob
Future, planned
Shocks
Replace headliner
The following 3 users liked this post by Probesport:
Silver one 125k, black one 103k
I do my own head work (aside from decking, my table just can't) but I'm starting light on the pulley and I haven't done a timing job on this one yet. My first step on these is always putting in the metal LS tensioners.
I've blown out MLS quite easily as well, when/if I start doing actual power id like to see a full copper or if there's room maybe o-ring this thing, but as of now I don't plan on going too far, this is my 'normal' car. I've seen there are some big power guys on here and I can absolutely appreciate that, but I have other toys for that.![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
How do you handle the valve job on yours? Do you have a valve grinder?
When I did a complete valve job on the 98’ XJR, the engine had 234k miles on it and I lapped every....damn....valve..
After I lapped them, I found practically all the exhaust valves were still leaking. I acquired 16 used exhaust valves and lapped them in also... 🤦 After that funhouse job, then came the absolute prison sentence like job of adjusting the valve clearance. I had a lot of shims available to me but with all the lapping that took place, certain sizes were not available and I ended up ordering about 4 or 5 from the dealer. If I had to redo that job again, to the machine shop they would go.
I do
it's an old Thor unit that I refurbed and it still works like a charm - but I mostly build older engines. We have a few machine shops here I'm still in contact with if I have to, one of the benefits of motor city life.
A lot of the time when there's not much improvement to be gained by valve jobs I buy used heads, tank them, and just have them decked and speced. I'm not as patient as I once was so I admire your tenacity there.
The following 2 users liked this post by Probesport:
Addicted2boost (04-10-2022),
Z07Brandon (04-09-2022)
Viktor Kurkov
07-06-2020 06:51 PM
