I have just installed a LPG on my cat
Since January 2012 the petrol prices went up a lot and reached 1.50 euro/liter or 7.50 U.S. dollars per gallon. This is kind of a local record and the worst thing is that the experts expect it to increase even more this summer.
That's why I decided to install LPG on my XJ8... I've always been against converting the engine to work on gas, because it brings nothing more than troubles, but since the price of the LPG is 0.50 euro/liter (3 times cheaper), I realized it's worth it.
I can't post a lot of experience because it's been only two days since I've got the car back from the workshop, but the torque and the power of the engine seem to be absolutely the same (already tried max speed and reached 235km/h on LPG), the acceleration is the same and the fuel consumption is absolutely the same - 16.5 liters / 100km urban driving.
The LPG system is Italian - Landi Renzo which is one of the best on the market right now. The total cost went up to 1400 euro (1850 US dollars) and it took 5 days for full installation. The LPG container is for 60 liters of gas and it's located in the trunk. It's "eating" a lot of the trunk space, but I can handle it
The car always starts on petrol and it runs on it until it reached both 40 degrees of coolant system and 1800 RPM - than it turns to LPG automatically. This happens without any signs - kicks or loss of power.
Here are some photos of how the engine bay is looking now:
This is the control unit inside the car. With it I can check the level of the LPG in the container and switch between gas and petrol:
![](http://img833.imageshack.us/img833/581/dsc0066yu.jpg)
This is the engine bay:
![](http://img571.imageshack.us/img571/1952/dsc0067wy.jpg)
![](http://img197.imageshack.us/img197/1862/dsc0068bu.jpg)
![](http://img839.imageshack.us/img839/7995/dsc0069ur.jpg)
The only problem I have with it up to now is a random "Restricted Performance". I'm sure that tomorrow morning the specialist from the workshop will be able to fix it, but unfortunately my new OBDII reader still haven't arrived.
I will post more information in the future after I test the car in different conditions.
So you have 60liters of LGP + 88liters of petrol (the factory tank) in your jag?? That much weight is not going to help fuel mileage very much. Also you were and are getting 16.5 liters / 100km, that is not good mileage (15mpg for the Americans here) - if you are really keen on saving fuel $ it might be worth investigating why your jag is getting such low mileage. Mine gets about that in aggressive stop-and-go NYC traffic.
FYI, Bulgarian fuel is not so expensive; 98ron petrol in Israel is $2.75-USD per liter!
Received 9,009 Likes
![Name: car01.jpg
Size: 19.3 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/165798d1501275456-i-have-just-installed-lpg-my-cat-car01.jpg)
Nice post and thanks for sharing.
I guess I'm surprised there aren't many more posts of this type with the way that fuel prices are going?
Haing said that the bulk of our members seem to be from the US and enjoy much much lower prices at around £3.16 per gallon, compared to UK £6.55 per gallon ( based on diesel )
I see however, that thats enough get people worked up at rising prices, so there may be more posts of this type soon I would think.
![Icon Pala](https://www.jaguarforums.com/forum/images/smilies/icon_pala.gif)
1. I couldn't install tank that it's big enough to feed the beast
2. If you put the LPG tank there you have two options:
- Drive without spare wheel and while driving outside the city I think it's a bad idea!
- Leave the spare wheel in the trunk... and the space that the wheel needs is much more than my 60 liter LPG tank
The other button is for opening the trunk. The image is a car with an opened trunk
And if you are curious enough - the other think, below the the buttons, that is inserted in the glove compartment is a Cobra radar detector
The rotary knob is the low beam regulator. You can use it to move up and down the front lights beam... for example if your trunk is to heavy (a lot of luggage and 3 persons on the back seats) the front of the car will rise up and your lights will dazzle and blind the other cars. Than you can use the switch to turn the low beam down. The default position always should be the highest set (in the XJ case this is the zero).
Loungagna (03-08-2012)
I forgot to mention - there is another option for different type of installation. Instead of LPG there is a system working on Methane (another type of gas). It has some advantages and a lot of disadvantages:
1. The price is incredible low. It's complicated to talk about price per liter because the Methane is calculated in kilograms but imagine that: run a XJ8 in urban with 5-6 U.S. dollars for 100km and for about 3-4$ for 100km on highway![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
Maybe this is the only advantage... if we forget about the fact the you can make a diesel engine work on Methane as well... BUT! Here comes the problems:
1. The entire system + the installation are more expensive than the LPG. It would cost about 2000 euro (2650$). Having in mind the price of the Methane it's not such a big deal.
2. Massive loss of power... A specialist told me I would have about 60%-70% of the total power of the car. Forget about the nice torque of the XJ V8 engine, forget about speeds over 180km/h.
3. Huge weight of the Methane tank. The fully loaded Methane container which will be enough for 200-300km run is about 300-400kg. Believe me - this is ruining your back suspension for an year. There is some new tanks made of carbon but the price for a normal tank would be about 1500 euro (+ the previous price I mentioned for the entire installation) and it will weight 200kg![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
4. Still there are not enough gas stations that offers Methane for cars. Here in Bulgaria we have about 10 stations in the capital and 10 more outside, mostly in the big cities. It's a good option for a urban car, but if travel a lot - not such a good idea. And the only place I've seen Methane stations outside Bulgaria is the homeland of gas systems - Italia![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
JKo could tell if there are any Methane stations in Finland for example?!
I don't think Methane is a good option for Jaguar. After all - this is a luxury car with style... and putting such a piece of technology in it would be like changing it for a Russian Lada![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
P.S> Methane systems are the most popular thing among taxi drivers
They don't need torque or power, they don't care about quality of suspension, they drive only in the city and they definitely want to run as cheap as possible
In the past two years the Mayer of the capital decided to invest and converted all the city buses to work on Methane (all the buses are Mercedes with diesel engines). The reason for that was the low price they could offer for tickets as well as the ecology - if you compare diesel with methane, the gas is much more clean for the environment.
In Finland gasoline is getting close to 1.7€/liter ($8.48/gallon), and LPG is not availabe widely enough to make conversions feasible. There is however cheap(er) E85 available for about 1€/liter (called RE85, made out of biowaste)... it does decrease mileage, but the price is so much cheaper that lots of ppl are converting their cars to FFV/flexifuel to run with it. Some just blend it with regular gas and run with E30-E70 blends without any modifications. I'm thinking about doing this myself... I wonder if there's anything that might go wrong with the increased amount of ethanol in the XJR, like the tank, fuel pumps, fuel lines etc?
There is a great deal of interest in running E85 in some tuner circles. The big deal for them is whether the fuel pump is E85 certified. That would imply that there would be an effect on your fuel system.
The other button is for opening the trunk. The image is a car with an opened trunk![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Don't worry I've not gone into this blindly I'd researched it, just haven't got round to having it done yet.
It is possible to put a tank in the spare wheel well it will also be of ample size. A space saver spare wheel, as supplied with many XJ8s, can be placed on top of the tank without causing any problems in the boot. I've seen this done on many cars including XJ8s.
Maximum sulfur content allowed in any fuel sold here is 10mg/kg (ppm), so it shouldn't be a problem. I think this is an EU wide regulation. Fuels sold in Russia may have higher sulfur content.
I did a bit of searching on the CNG (compressed natural gas, mostly methane I guess)... there is one station selling this quite nearby, and a conversion for an 8 cylinder car would cost something like 3,000-3,500€. Savings in fuel costs would be around 1,000€ per year (with my yearly mileage). And the trunk would look something like this (pic is from a Chrysler 300C):
http://oragas.fi/images/stories/pa160314.jpg
Not quite convinced.
