I just changed my own timing chain tensioners........HOW TO
Old 07-26-2015, 10:40 AM
Jhartz's Avatar
Before it runs out, go buy a lottery ticket!
  #302
Old 07-27-2015, 06:51 AM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
Did Harvest ever post the results for his VVT code episode?
  #303
Old 07-27-2015, 10:32 AM
harvest14's Avatar
Default Resolution, sorry for delay.
When I changed the oil in the car, which was my wife's car but now is MY daily driver (bought her a 2004 XJ8 that she fell in love with), the oil coming out didn't look too good. I ran Castrol 10w-30 synthetic blend for about 1,500 miles then drained again.
I dropped the pan for a thorough cleaning and new gasket (no plastic parts found anywhere) and refilled with Mobil 1 full synthetic 5w-30. The VVT codes disappeared after the first oil change, and have never reappeared. My theory is either the oil quality was too poor and/or the oil filter was clogged. It is certainly possible that during my tensioner replacement procedure I broke loose sludgy deposits or something that could have restricted proper oil flow.
sparkenzap (07-27-2015)
  #304
Old 07-27-2015, 12:06 PM
sparkenzap's Avatar
Great! Glad you got it sorted. Uh, Oh, you are hooked on the Jaguar obsession. It leads to many questionable decisions!
  #305
Old 07-29-2015, 06:18 AM
Originally Posted by harvest14
They are torqued somewhere between 22 and 27 ft. pounds but I did them that tight because they were remarkably difficult to loosen when I took them off.
Jeff
I am 99.9% certain that the factory uses thread locker on the cam cap bolts when assembling the engine.
When I did my tensioners, I could literally smell the thread locker when the cam cap bolts finally broke loose.
I did not use thread locker when I re-assembled and as far as I know neither has anyone else.
Vector
harvest14 (07-30-2015)
  #306
Old 07-30-2015, 11:36 AM
harvest14's Avatar
Maybe it's good that I over torqued them then, since I didn't use any thread locker...
  #307
Old 07-31-2015, 05:57 AM
RJ237's Avatar
Received 2,801 Likes on 2,236 Posts
You are missing the plastic shoe from one tensioner. The pieces will end up in the oil pickup screen and could reduce flow to the pump. It would be a good idea to drop the pan and remove the pieces.
  #308
Old 07-31-2015, 08:05 AM
Samilcar's Avatar
I'm planning on doing that at some point in the future. The existing oil pan has some fairly extensive rust, so I want to replace it with a less corroded used part anyway.
  #309
Old 08-01-2015, 05:20 PM
Over torquing is usually not a good thing.
Torque and thread locker are not the same thing.
Torque ensures the proper "tension" on the bearing caps, and the thread locker just makes sure it stays that way.
You will probably be OK, but usually torque figures for engine components are an important guide to follow to the letter.
My first experience with this was when I cracked the aluminum timing cover on my Lotus twin cam engine by over torquing the bolts about 40 years ago. Aluminum welding was very expensive in those days, but not as expensive as buying a new cover from Chapman. Or as tough as waiting the two to three months it took to get parts across the pond back then.
Vector
  #310
Old 09-04-2015, 05:27 AM
Mooltan's Avatar
My XF 3.0 Diesel died suddenly. Among other things I tested the compression and noted lack of compression in Number 5 cylinder. Took camshaft cover off and there was a broken camshaft timing chain. Closer inspection showed one of the plastic runners on the tensioner had broken off. The broken runner had deep sprocket marks along its length. I strongly suspect the runner broke and caught between the sprocket and chain resulting in the chain snapping.
Has anyone had a similar experience.
  #311
Old 09-04-2015, 09:07 AM
Jhartz's Avatar
You are on the wrong forum.y
  #312
Old 09-06-2015, 09:00 PM
convincor's Avatar
Default Source for Tensioners
Being new to the forum and not seeing the need for yet another tensioner thread... Let me just ask here..
Are there any preference on where to get parts for tensioner upgrade?
Are the ebay kits OK?
  #313
Old 09-07-2015, 12:30 PM
Jhartz's Avatar
  #314
Old 09-07-2015, 08:21 PM
Mooltan's Avatar
The jaguar manual suggests using thread locker on the chain tensioner mounting bolts and the all the camshaft seal cap mounting bolts but not the intermediate camshaft journals.
  #315
Old 09-09-2015, 05:13 AM
grandell's Avatar
Finally getting around to this myself. Just put in an order with SNG Barratt for tensioners, gaskets and a couple of other items I need for the upcoming 120k service.
However, they don't have the 35mm bolts I need for the upgraded tensioners
Does anyone know who has these? I'm sure I could go through the local dealer, but I'd rather not pay $20 per bolt :P
Head Flanged Bolts: part number JFB10607E
  #316
Old 09-09-2015, 05:47 AM
Received 6,312 Likes on 5,499 Posts
Any hardware supplier should have them, some people have cut the old ones.
  #317
Old 09-09-2015, 08:25 AM
Samilcar's Avatar
I believe JFB10607B025 is the Eurospare part number for the shorter secondary tensioner bolt.
grandell (09-09-2015)
  #318
Old 09-09-2015, 12:07 PM
Sean B's Avatar
Received 1,357 Likes on 1,068 Posts
Have you a Land Rover dealers? Ask them?
  #319
Old 09-09-2015, 12:30 PM
harvest14's Avatar
Default Quick question on this topic...
The correct bolts for the new secondary tensioners I received from Christopher's Foreign Car Parts, came with the tensioners.
I am doing my timing gear next week and other than sourcing the crank holder/puller I have everything I need. My question is probably a very simple and common sense one, but given the critical nature of the timing system I will ask just to be on the safe side.
My secondary tensioners are only 5 months old. I am now going in to replace the rest of the timing gear. Is there any special directions since I will NOT be removing the secondaries? My plan was simply to put a large wire-tie around each one holding it at it's current extension. Then, when the new chains are on, removing the wire-tie. This may not even be necessary but I'm not really clear on how they operate.
Could someone address this for me?
Thanks.
  #320
Old 09-09-2015, 04:16 PM
Dicque's Avatar
Default Timing chain and teneioner replacement
Looks good.
I hope to have my own success story soon. will inform all
Quick Reply: I just changed my own timing chain tensioners........HOW TO
