I need help with lowering my XJR
Guest
Posts: n/a
Hello to all! I am new to this forum. I have a 2000 XJR and have made several nice mods to her but I wanted the car to have the right stance. I ordered the Mina Gallery lowering springs and now the car looks great but sits so low that it rubs horribly. I was advised at the time of purchase of the springs that if I had two to three fingers room between the tire and fender lip I would be fine! Well, I had that much space but now the technician that installed the parts thinks I will get to many problems from the springs. Has anyone had any experience with these springs or can you make suggestions! I am open to any ideas, and yes I have the original springs and know that I may have to put them back in. They just dont give me the "stance " I was hoping for. Any help would be appreciated!
Where do they rub? I have a 99 XJR lowered with Arden springs and never had an issue running 8.5 inch rims in front and 10 inch in back. I did have the shocks revalved to stiffen up the compression and rebound rate to be able to handle the increase in spring rates. How old are your shocks? The stock shocks can not handle any increase in spring rates IMO.
This should give you an idea of the stance you would acheive by using lowering springs with stock wheels and aftermarket wheels. The car here is using Arden springs. I'm not sure how low Mina springs lower the car in relation to stock height. The Arden springs lower the fronts about and 1.5 inches and rear about 1.25 inches.
Received 10,873 Likes
my 2 pence, the XJR is lowered 15mm over standard, 308's have camber adjustment. If you want "the look" buy bigger rims, they look perfect on 19 inch in my opinion. Lowering just messes the whole issue up. Jaguar spend thousands of hours on the proving ground at Millbrook to perfect the ride. Why do you think they have many bushes in the suspension. The one very strong thing about these cars is the suspension, you want sports car handling, buy a Lotus.....
Ipc838
09-13-2015 03:27 PM
