I smell burned oil when I stop at a stop sign and when I turn the Jag off
Received 1,795 Likes
I believe this is what highorse more or less was referring to. It’s located on the same side as the oil filler cap. The part load breather is the side that can get clogged up so bad that I’ve seen air filters soaked with engine oil because the PL breather was nonfunctional and it would get sucked out thru the full load breather going from the valve cover to the air intake tube when it’s supposed to be flowing out of the PL breather. A clogged PL breather will also cause excessive pressure inside the engine and cause oil leaks.
https://www.jaguarforums.com/forum/a...e-breather.pdf
Highhorse (07-12-2020)
BrentGardner
10-11-2013 03:53 PM
