i930 carsoft code reader
I'm after any thoughts on this reader ? Looks like it reads and adjusts everything! After it for security module reading and setting anyone got one and used it for this , can you just replace the security module with another from same year and programme it to car with the i930 ?
Thanks Geoff
Thanks Geoff
The following 2 users liked this post by Datsports:
Don B (02-12-2017),
Geofflvmyjag (02-12-2017)
I have one along with an Autel Maxdiag Elite 802, Maxdiag Elite 702, and VCM/IDS. The i930 sits in the boot and is used only in an emergency if the other scanners aren't present. Personally I have found it as useful as any generic $30 scanner. Cannot "adjust" anything and def cannot program. Slow to diagnose IMO as well. Might not communicate with my early '98 modules as well as other newer models, who knows
The following 2 users liked this post by greverrr:
Don B (02-12-2017),
I have an i930 Carsoft, and it does read earlier models (mine's a 1998), but as said, it doesn't programme anything, it will only read and clear faults. I read on here that modules can be replaced with ones of the same year, and that after changing doing a hard reset (touching earth lead onto positive on the battery) will reset modules to 'learn mode'? I changed a seat module, did a hard reset and it worked a treat, but not sure about security models?
