Idle problems
Hi looking for some advice, my 2001 xjr has a problem with the idle. It runs fine over 1000rpm and when I obd it it comes up with missfires on all cylinders. It is not the tensioners and I have looked for vacuum leaks and can't find any, I have changed the spark plug and the air flow sensor but no better.
Any suggestons
Any suggestons
![Icon Confused](https://www.jaguarforums.com/forum/images/smilies/icon_confused.gif)
Hi I think I have sorted it found a missing o ring on the engine breather pipe. Thanks for your help but I may be back if its not fixed and I'll give you all the code next time I check them.
PS. I cant start the car at the moment as I am modding the supercharger nose to fit a new pulley but I should get it going on monday.
Cheers Guys![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Cheers Guys
Thang Nguyen
10-12-2015 01:25 AM
joesoap
09-10-2015 01:09 AM
