ignition coil 3, circuit c misfire
matyx:
The chart has been posted several times. If you cannot find it in the archives, post back and someone will help find it. With only one digit in your cylinder number, you must be refering to the OBDII designator, which is 1 through 8, with 3 correseponding to the Jaguar cylinder number A-3, which is third back on the right hand (US passenger) side.
You will find the chart in the XK8/R forum FAQ Sticky. It has been modified from the JTIS charts to display the OBDII code identification.
https://www.jaguarforums.com/forum/x...ts-data-29800/
