Ignition coils
Ignition coils
Hi there,
Are the ignition coils interchangeable? Sounds weird but can I use later 2 pin versions on my 2 pin coil cat? Jaguar says that there are two numbers: Either LCA1510AB or XR827823
The only note is to VIN F00034 for the first, and from F00035 for the latter.
Can Imuse the earlier on a later or a later on an earlier car?
Damien
Damien
Received 1,798 Likes
IMO, there is a reason they specify such for the VIN's, it can be because of the ECM or the wiring detail or a change in EPROM, it can be a number of things. To err on the side of caution never hurts.
But I also reference such things, so I will simply do a Bing search using the part number and see what prevails. Many times a link will come up showing a thread or threads on sites regarding the item. I also use this site... https://frugalmechanic.com/ ...to see what comes up. As time goes by manufactures may find a common build type that allows for use on both VIN's, but always check before applying (like you are doing now..) and check the date of the post.
Hi there,
Can I use the earlier on a later or a later on an earlier car?
Damien
Damien
The big difference came with the 4 pin coils as used on AJ27 engines.
At least that is how I view it ;o)
Jaguar Forums Editor
Jaguar Press release
09-08-2016 04:28 PM
09-07-2016 04:48 PM
