Ignition fault p0353 2000 XJ8
Hi there,
wondering if anyone can give me some help with this error.
I Believe its for a bad coil on cylinder 3.
I have replaced the plug and the coil for this cylinder.
I still get p0353. I then switch the plug and coil with cylinder 1.
Still got p0353. Usually the car runs perfect for the first drive then goes to restricted performance after parking.
At this point I think it might be the ignition wiring, have checked it but can't see any cuts etc... and dealer tells me it $1300 for the wiring harness.
Any suggestions as to what i should do?
Anyone had a similar problem and solved it?
