Im sure this has been covered already...
Bought a 2000 xj8 about 6 months ago. 100,000 miles. First two months went great. Then my throttle position sensor went out so I replaced it. In the meantime the abs unavailable, Trac unavailable, and gearbox fault lights have all came and went. Remove battery cable and it was good for a week or so. Tried to start it yesterday and it refuses to. Undone the battery cable like I usually would in this case and left it off for about 30 minutes, tried to start again and still nothing. The car runs great when it wants to start. Transmission shifts great. No loss of power. Just had a full tune up about a week ago. So if anyone on here can help me out with what could possibly be causing the messages to show and why it won't start I would greatly appreciate it.
Need more info.
Does the starter work?
Does it turn over but not start?
Or not turn over at all?
Could be a bad battery, bad grounds or other connections, inertia (impact) sensor, fuel pump, etc., +100.
As was said, get it running, if you can, and pull some codes.
Vector
Vector
Definitely sounds like these cars require a good, strong battery. Most auto parts store testing is insufficient and can give a false sense of the true condition of the battery. I just bought an '03 XJ8 with 100K and while I'm not having these issues (yet), I'm going to replace the battery ASAP.
Can anyone tell me the locations of all the critical ground connections on these beasts? Long time British car owner and I know how important they are and all the gremlins they cause if not good and solid.
Thanks for the help!
Please post the codes you have pulled here!
Do not depend on the local auto parts store or the internet to correctly interpret the codes for your jag.
Give us the info we need and let us help you.
Vector
Vector
Michael Wittmann
03-29-2016 05:16 PM
Michael Wittmann
03-27-2016 07:45 PM
