IMT location
First off, your car shouldn't have IMTs, from what I know. Yours should be the (relatively) same supercharged 4.0 as in the XJRs.
Cracks in the intake runner between the air filter and throttle body are a possibility, and cracks in either of the two engine breathers are very common.
Pop all those parts off, check carefully for cracks, then spray the MAF down using MAF spray from any auto parts place. Put it back together and see what happens.
Are you using a K&N filter?
jimforrest (uk)
02-28-2019 07:42 PM
FS[SouthWest]: 19" Aquila Wheels with Tires
jorgef858
01-14-2016 12:32 PM
