Installed Mina Exhaust
I met up with Viapa to buy his Mina pipes for cheap. It is a behind-axle system. After a trip to Autozone for 2" clamps I was set. The next day I rolled the back wheels up ramps and had everything unbolted and off within an hour. Installation was even easier after swabbing the ends with caliper grease. The polished pipes look good. I need to make a fit adjustment since they are a little cockeyed. I had the center resonator replaced with straight pipes a while back and this combination sounds good on initial startup and a neighborhood cruise. I will report back after a few days of driving.
Pics after install. The sound is mellow and respectful to the brand and doesn't draw much attention. The deep growl comes out the back instead of coming in the cabin. Since my resonator was removed a little more rumble already is coming in from underneath. With as little as I paid, I am happy with the modification.
![](http://i141.photobucket.com/albums/r64/blackjelli/fa7698e1.jpg)
![](http://i141.photobucket.com/albums/r64/blackjelli/4feba78f.jpg)
burmaz (10-17-2011)
The large, center resonator located directly underneath the cabin had developed a buzz and had to go. Two independent pipes were welded in its place. I think it was designed to eliminate low frequency tones since a deeper exhaust sound appeared when it was replaced.
Btw I like your Volvo V70R. Those look much better/classier than the Volvo XC90 by far.
Would you recommend just removing the center resonator? Does it drone on the highway or make any noises that are annoying? Mine has a small leak, and I'm tempted to remove it. I would like my exhaust to sound exactly the same as stock, but just deeper in tone. A performance sounding exhaust is great for a XJR, but not so much for a Vanden Plas so I would like to only slightly increase the sound.
The V70R is very different than the XC90 even though it is on the same platform. I like wagons more than SUVs.
If ever there was an engine designed to be heard it was the V8. I would like more of the gurgle from mine to be heard. Sean B's XJR 100S has a full paramount system fitted which sounds pretty good and doesn't produce an offensive drone. If you stood on the kerb to hear it pull away you wouldn't hear much because it's so fast! :P
This is some acceleration in second gear near my neighborhood to let you hear inside the car. Notice how it stays mellow while still making a good V8 sound (over the SC whine). Mina Exhaust Sound Inside 03 XJR - YouTube
That does sound good. I doubt mine sounds just like that tho. Prob more mellow. I'll try to get one of my kids to record a launch like that video. But since he's seven, I gotta make sure he doesn't blab to his mom that "Dad is smoking the tires again!"
