Installed a rear anti-roll bar on a VDP S/C
Old 07-04-2014, 09:29 PM
J.Bo's Avatar
Originally Posted by VIAPA2
I am currently having the rear anti sway bar taking from Thundercat's XJR and having a metal plate fabricated (to house the rear sway bar) for my 01 VPD SC. I'll have an update coming soon!
keep us posted.
Old 08-26-2014, 12:45 PM
VIAPA2's Avatar
Default Rear Anti-Roll Bar project completed!
Originally Posted by J.Bo
keep us posted.
Ok the project has been completed. The ride quality is as smooth as glass! The noticeable differences are when you are at a stop light getting ready to make a left turn the VDP SC is noticeably flat through the entire turn. The sensation is like you're anticipating the car to roll to its right but it stays entirely flat. The roll bar makes a dramatic difference! In a straight line the roll bar works in conjunction with the CATS suspension. Not as tight as the XJR in the rear but a very controlled refined ride. The VDP SC bounds over bumps. Take into consideration that the VDP SC has a Touring tuned suspension compared to the XJR's Sport tuned suspension. I strongly recommend it!
Old 11-15-2014, 09:39 AM
darkwing99's Avatar
Dear Rocklandjag, I am new to the forum and have acquired a rear sway bar and end links. Like VIAPA2, I too would like the dimensions and hole locations of the 3/8 in. plate to have one fabricated. Thanks in advance.
EF
Old 09-19-2015, 09:09 AM
Col. Sandurz's Avatar
Does anyone have the dimensions for this?
Any other ways to add the rear sway bar?
Old 10-04-2017, 03:53 PM
Ric in RVA's Avatar
Resurrecting a dead thread I know....but if anyone has measurements please let me know.
If not I will pull mine and measure but would rather not.
Who is interested in a rear roll bar mounting plate?
Old 10-07-2017, 09:52 AM
I ended up installing a different mount with the brackets. I actually have an extra one sitting in my garage right now.
Old 10-08-2017, 09:15 AM
Ric in RVA's Avatar
OEM mount or fabricated plate?
I am interested in either one .
  #28
Old 10-15-2017, 10:15 AM
Ric in RVA's Avatar
Have you got dimensions you can share?
Old 10-16-2017, 08:07 PM
Here are some quick directions to replacing the wishbone mount.
In these pics I am taking one off with the mounts but process is same and this is how it can be done.
Jack up rear end, taking wheels off will give you more room to work. Once up, put jack and something across the rear diff and control arms and raise it up just to release tension on K-bar.
I used a 2x4 for this and did not have any issues with the control arms moving around once fulcram bolt was out.
Here I would remove lower K-bar bolts and lower the diff just enough to free it.
Remove the control arm bolts. 21mm on front side and 19mm on back
Here I used a larger wrench to pry out bolt while backing it with wrench.
Long bolts....
Do the other side, then remove the 21mm bolts holding the wishbone on the back of the diff. Replace with new wishbone with mounting plates. Reassemble.
  #30
Old 03-27-2021, 09:48 AM
gerardbooth's Avatar
Sorry to resuscitate an ancient thread, but did anyone ever get hold or share the dimensions of that home made tie bar for the anti roll bar to mount to...
Ungn
04-20-2019 10:15 PM
greverrr
06-22-2016 10:18 AM
SD96XJ6L
10-05-2015 09:48 AM
alanmurg
10-17-2014 07:15 PM
J.Bo
01-25-2010 07:17 AM
Quick Reply: Installed a rear anti-roll bar on a VDP S/C
