Instrument Cluster flickering XJ8
Does it happen when the car is sitting still? Or only when in motion?
I ask because I can't see any common connection between the two systems. If it is only when bringing the car to a stop, I look for a loose connection on the back of the instrument panel.
Are there any other lights affected? The climate control, for example?
For what it's worth, a similar problem happened on a xj6 (x300) that belong to my father. Turned out to be a faulty coil ! Can't really remember how my dad and I came across that as a possible solution, but I do recall us being very happy to have solved it for relatively cheap and easy! Now, your description appears narrowed to specific situation, which was not the case here. What I have discovered recently on my xj8 (x308) though is that there is some gremlin living under the dash. My windshield fluid pump stopped working when pressing the button. Thought it was the pump. Looked under the dash (above pedals) and played around with the wires, looking for loose ends. Did not discover anything obvious besides the fact the pump started working again! Hence, some wiring short of some sort. With you referring to the problem when braking, me thinking stop light switch at the pedal, wires under dash... You know where I'm heading. Again, for what it's worth....
The last three issues are probably unrelated. The clock lamp may be burnt out (it's easy to check, pry off the wood panel, unscrew the clock and pull the bulb).
The J gate doesn't light in either of my cars, and the headlights are always on in my North America market cars, not sure about the rest of the world.
The biggest clue is, what happens if the car is sitting still and you press the brake?
Correction . I changed the CONSOLE SWITCH PANEL and heater panel and not the instrument panel .
I still have the flickering and eventually loose all the lighting in the console , heater and instrument panel. I also still have the battery not charging light on even when it is charging .( new battery and alternator ). The lights may go back on and off when I play with the light switch and high beams.
Can this be related ?
Thanks for your help.
Received 12,932 Likes
goges
10-05-2015 04:53 PM
